Trips - start odometer
A couple things when entering a trip. It would be helpful if the ‘system’ automatically used the last entry for Vehicle and towed Vehicle. Just one less entry to have to make and you might ‘assume’ that you are, in most cases, just resuming your trip with the same configuration. Also, that would be the case with the “start odometer” since it is a continuation from the last stop. And finally, it might also apply to the “start location”. I find (especially for odometer) I have to remember to look at the last trip record and write down the finish odometer reading before I start a new trip record. Kinda a pain when I forget to do that.
Also kind of strange on notes tab - the notes text area works as almost every text area with entry starting on the top left. The highlights text area is different and types backward from the top right which feels strange and also makes editing awkward. Can the highlights text box be the same as the notes area??
Laptop with 4.0.7
All fixed for the next build (v4.0.9), thanks Steve.
