Syncing gone again
I exported the copy I was in because every time I tell it to resync it wipes out current data, so I pulled in the back up copy and it also did not have trip info I thought would be saved and also it wipes out all documents in the vehicle section every time.
Good news is it did finally resync to the phone
So here is a new one, I got up this morning and checked to see if it synced, it has doubled all the entries are doubled! So I did a resync and it came back correct then a few minutes later it doubled them again and then a few minutes later it deleted everything but 4 components and the campground
Version 4.0.7 (2075) | macOS 26.5.1
Generated: Jun 22, 2026 at 8:43 AM
Last successful sync: 8:42 AM (36 successes this session)
• [8:41 AM] Import – The operation couldn’t be completed. (NSSQLiteErrorDomain error 769.) · domain=NSSQLiteErrorDomain | code=769
Sync detail (last 10 min):
8:39:22 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason: Store Removed
8:39:32 AM CoreData+CloudKit: -[PFCloudKitImportRecordsWorkItem checkAndApplyChangesIfNeeded:]_block_invoke(789): : Failed to incrementally apply changes during request: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:06 AM CoreData+CloudKit: -[PFCloudKitImportRecordsWorkItem fetchOperationFinishedWithError:completion:]_block_invoke(699): - Fetch finished with error: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:08 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _importFinishedWithResult:importer:: : Import failed with error: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:08 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:08 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _recoverFromError:withZoneIDs:forStore:inMonitor:: - Failed to recover from error: NSSQLiteErrorDomain:769 Recovery encountered the following error: (null):0
8:41:08 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:08 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _requestAbortedNotInitialized:: - Never successfully initialized and cannot execute request ‘’ due to error: Error Domain=NSSQLiteErrorDomain Code=769 UserInfo={NSSQLiteErrorDomain=769}
8:41:10 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate _respondToPushNotification:forSubscription:]_block_invoke(912): - Reviving the mirroring delegate after notification for subscription: com.apple.coredata.cloudkit.private.subscription
8:41:10 AM CoreData+CloudKit: -[PFCloudKitSetupAssistant _checkAndInitializeMetadata:]_block_invoke(174): Failed to initialize CloudKit metadata: Error Domain=NSSQLiteErrorDomain Code=6922 UserInfo={NSSQLiteErrorDomain=6922}
8:41:10 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate _performSetupRequest:]_block_invoke(1230): : Failed to set up CloudKit integration for store: Error Domain=NSSQLiteErrorDomain Code=6922 UserInfo={NSSQLiteErrorDomain=6922}
I restored my last file and so far it is ok on the laptop and the phone
