Sync problems with pictures
So, I am being very careful after backup/restore concerns and syncing. After updating everything lost, I stayed in sync for 5_ days on all devices. But: that was only using fuel, trips and Cg/Reservations and nothing out of the ordinary entries. NO photos for CG’s.
I started updating ‘Enhancements" again (appears to be what caused the sync problems last time) and have been checking sync after each entry. no problem until I tried to add a photo. didn’t appear to work at first, not showing a picture in the image tab But, it showed the picture as part of the list. About a minute later, after switching between tabs and enhancements, a picture finally appeared in the image tab BUT, it threw a sync error. I waited over two hours for it to try to resolve the sync error but no go. It still shows a sync error on the laptop (where I was doing the enhancement entries) and nothing else I entered has been sync’ to the other devices. It appears that once a sync error is encountered, nothing else will sync after that.
Here is the sync error:
Version 4.0.11 (2091) | macOS 26.5.2
Generated: Aug 9, 2026 at 2:52 PM
Last successful sync: 2:10 PM (522 successes this session)
• [2:11 PM] Export – Partial failure [CK2] · domain=CKErrorDomain | code=2
Sync detail (last 10 min):
2:11:02 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _exportFinishedWithResult:exporter:: : Export failed with error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9a12fb720 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
2:11:02 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9a12fb720 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
2:11:02 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _recoverFromPartialError:forStore:inMonitor:: : Error recovery failed because the following fatal errors were found:
2:11:02 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9a12fb720 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
2:11:02 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _requestAbortedNotInitialized:: - Never successfully initialized and cannot execute request ‘’ due to error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9a12fb720 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
2:11:07 PM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason:
Yes, that seems to be the case every time there is any sync error. That’s not the way it’s supposed to be (obviously). Sync is supposed to recover regardless of what has happened.
I’ve been working for the last few days on a rebuild of the sync stuff, and I won’t release it until it’s 100% perfect. Sorry for the issues you have suffered.
Any idea on what to do with my phone or computer app? I have nothing, dont know if my data is still alive or not, :frowning: Better than 10 years of campground stuff.
