Spoke too soon - double entries
I downloaded 4.0.10 to Laptop about 1 hour ago and everything looked fine. I went and downloaded to my iPhone and that even picked up the reservation that was missing but . . went back to the laptop and every entry has been duplicated. I now have two of everything!!
and now my iPhone is the same way - double entries!!
Worse yet - It has been duplicated in my local copy!!! I have a backup but I have no idea if that will ‘fix’ it or if sync copy is also corrupted!!!
And to make it even worse - I tried to reset on the iPhone - it brought back duplicates for everything which means the iCloud sync copy is duplicated!
Mine isn’t syncing, I backed up file on both phone and computer, tried sycning and no go, reload file on phone and it never saved the last fuel or trip entry I just made before saving. :slight_smile: do you have any hair left Gavin? lol
pulled it all out or will soon :slight_smile:
Version 4.0.10 (2088) | iOS 26.5.1 · iPhone
Generated: Jul 5, 2026 at 9:55 PM
Last successful sync: 9:50 PM (1 successes this session)
• [9:50 PM] Export – Partial failure [CK2] · domain=CKErrorDomain | code=2
Sync detail (last 10 min):
9:50:16 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _exportFinishedWithResult:exporter:: : Export failed with error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x1187f3270 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:50:16 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x1187f3270 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:50:16 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _recoverFromPartialError:forStore:inMonitor:: : Error recovery failed because the following fatal errors were found:
9:50:16 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x1187f3270 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:50:17 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _requestAbortedNotInitialized:: - Never successfully initialized and cannot execute request ‘’ due to error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x1187f3270 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:50:22 PM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason:
9:54:06 PM CoreData+CloudKit: -[NSCloudKitMirroringDelegate _respondToPushNotification:forSubscription:]_block_invoke(915): - Not reviving the mirroring delegate (CKErrorDomain:2) after notification for subscription: com.apple.coredata.cloudkit.private.subscription
Just updated and I have now got duplicates of everything. The worst possible outcome.
Lots of work required to remove duplicates to sort out the database.
@SteveJ @JonH82 I’m sorry about the duplicates. For what it’s worth, v4.0.10 improves a number of things in terms of syncing and backups which new users will see. For us existing users who had previous problems, we’re still cleaning those up unfortunately.
On launch of the new version, there should have been a backup created automatically and immediately, before syncing begins. At that point, there should not have been duplicates.
Please try to do a backup of the way things are at the moment on the phone (just for safety), and then try to restore the earlier backup.
If you (or anyone else) wants to share their backup file with me, I can confirm if it’s good or not before proceeding. Just choose Export / Share and send it via email and I’ll get back to you as quickly as possible.
It may be necessary to do a “Clear All Data” on all devices and restore a backup. I’m working on testing this at my end.
Not a massive problem for me. I deleted all the duplicates then did a manual backup. Seems to be working pretty good now. It’s not doing iCloud backups even though it’s set to. But it is syncing across devices ok.
I just had this happen on my phone it duplicated campgrounds but I think ONLY campgrounds. Computer says it syncs ok now but nothing is changing on my phone and when I change on my phone it doesnt change on computer, I dont know who it thinks it is syncing with :slight_smile:
Mine duplicated everything.
So this is becoming a real problem that I can’t solve. Cleared all data from all devices. Used a restore that brought back everything correctly (except last reservation) - everything looked good. Didn’t do anything - just let it set. Within 20 minutes, the laptop showed complete duplicates. I cannot prevent this no matter what I do. I guess I could disconnect from the cloud but I have lots of other stuff I need access to. There is no way to clear the iCloud sync database and there is no way to shut off the active sync. What can be done - I need to make trip entries??
What I did was to remove all the duplicates manually and let it sync. It now seems to be syncing normally and the data is now correct. It’s a bit of a pain but worth the time. But be careful to remove only the duplicates as it’s very easy to remove both entries especially the trip logs and the fuel entries.
Hi @SteveJ - this is good info. Just to check, if you clear data from all devices and do not do a restore, both devices remain empty of data, even after a little time, right?
My last computer sync
Version 4.0.10 (2089) | macOS 26.5.1
Generated: Jul 7, 2026 at 10:34 AM
Last successful sync: 10:34 AM (46 successes this session)
• [9:35 PM] Import – Partial failure [CK2] · domain=CKErrorDomain | code=2
9:35:10 PM CoreData+CloudKit: -[PFCloudKitImportRecordsWorkItem fetchOperationFinishedWithError:completion:]_block_invoke(699): - Fetch finished with error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9f7a2e5e0 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:35:10 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _importFinishedWithResult:importer:: : Import failed with error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9f7a2e5e0 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:35:10 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x9f7a2e5e0 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
9:35:10 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate logResetSyncNotification::
9:35:10 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=CKErrorDomain Code=21 UserInfo={ContainerID=, OperationID=, NSDebugDescription=, RequestUUID=, errorKey=, ServerErrorDescription=, CKErrorDescription=, NSLocalizedDescription=, NSUnderlyingError=0x9f7a2f180 {Error Domain=CKInternalErrorDomain Code=2026 UserInfo={ContainerID=, OperationID=, RequestUUID=, errorKey=, ServerErrorDescription=, CKErrorDescription=, NSLocalizedDescription=}}}
My last phone sync. They don’t intermingle at all
Generated: Jul 7, 2026 at 10:37 AM
Last successful sync: 10:34 AM (1 successes this session)
• [10:34 AM] Export – Partial failure [CK2] · domain=CKErrorDomain | code=2
10:34:24 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _exportFinishedWithResult:exporter:: : Export failed with error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x119972250 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
10:34:24 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x119972250 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
10:34:24 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _recoverFromPartialError:forStore:inMonitor:: : Error recovery failed because the following fatal errors were found:
10:34:24 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x119972250 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
10:34:24 AM CoreData+CloudKit: -NSCloudKitMirroringDelegate _requestAbortedNotInitialized:: - Never successfully initialized and cannot execute request ‘’ due to error: Error Domain=CKErrorDomain Code=2 “CKInternalErrorDomain: 1011” UserInfo={ContainerID=, NSDebugDescription=CKInternalErrorDomain: 1011, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0x119972250 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
10:34:29 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason:
Well, cleared the iPhone - it also just cleared the iPad with no request from me. Doing a clear on the iPhone did not clear the laptop - that is still duplicates . .
I just cleared the laptop - now have three cleared 4.0.10 - so far, no data . . .
Within an hour, all three devices had reloaded by themselves - nothing I did . . .
OK, it appears to be back in order - I loaded 4.0.11 on all three devices. and loaded a backup about 5 hours ago. Nothing has been duplicated since then. Hooray!! Entered trips/fuel and reservations and they all appear to work and sync . . .
All good this morning!! Back to lots more entries!! Working on updating inventory with pictures!! Whee!! Doesn’t that just sound like loads of fun??!!
Tried to restore file and got this report
Translated Report (Full Report Below)
Process: RVCare Logbook [629]
Path: /Applications/RVCare Logbook.app/Contents/MacOS/RVCare Logbook
Identifier: com.jimsmithsoftware.rvcarelogbook
Version: 4.0.11 (2091)
Code Type: ARM-64 (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: com.jimsmithsoftware.rvcarelogbook [679]
User ID: 501
Date/Time: 2026-07-09 14:03:00.9905 -0400
Launch Time: 2026-07-08 17:56:06.4055 -0400
Hardware Model: Mac17,3
OS Version: macOS 26.5.1 (25F80)
Release Type: User
Crash Reporter Key: 807D8CDC-F379-CAAE-98B9-34C3A047F954
Incident Identifier: 2EBA2139-1F62-4730-8DF1-B9092EC6953A
Sleep/Wake UUID: 2DC7FFE0-EC2E-411D-BE2E-CA850296B586
Time Awake Since Boot: 36000 seconds
Time Since Wake: 3354 seconds
System Integrity Protection: enabled
Triggered by Thread: 0, Dispatch Queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6, Abort trap: 6
Terminating Process: RVCare Logbook [629]
Application Specific Information:
abort() called
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x182e4a5e8 __pthread_kill + 8
1 libsystem_pthread.dylib 0x182e858d8 pthread_kill + 296
2 libsystem_c.dylib 0x182d8c644 abort + 148
3 libswiftCore.dylib 0x1965ac0ec swift::fatalErrorv(unsigned int, char const*, char*) + 144
4 libswiftCore.dylib 0x1965ac10c swift::fatalError(unsigned int, char const*, …) + 32
5 libswiftCore.dylib 0x1965a024c swift::swift_dynamicCastFailure(void const*, char const*, void const*, char const*, char const*) + 80
6 libswiftCore.dylib 0x1965a03f4 swift::swift_dynamicCastFailure(swift::TargetMetadataswift::InProcess const*, swift::TargetMetadataswift::InProcess const*, char const*) + 164
7 libswiftCore.dylib 0x19654c78c swift_dynamicCast + 288
8 SwiftData 0x22fa39134 0x22f912000 + 1208628
9 SwiftData 0x22fa36404 0x22f912000 + 1197060
10 SwiftData 0x22f9c8624 0x22f912000 + 747044
11 RVCare Logbook 0x102c1586c 0x1028f8000 + 3266668
12 RVCare Logbook 0x102be6a64 0x1028f8000 + 3074660
13 RVCare Logbook 0x102c4572c 0x1028f8000 + 3462956
14 RVCare Logbook 0x10290d904 0x1028f8000 + 88324
15 RVCare Logbook 0x102c8fb85 0x1028f8000 + 3767173
16 RVCare Logbook 0x102901491 0x1028f8000 + 38033
17 RVCare Logbook 0x102918269 0x1028f8000 + 131689
18 RVCare Logbook 0x10291826d 0x1028f8000 + 131693
19 libswift_Concurrency.dylib 0x287813ec5 completeTaskWithClosure(swift::AsyncContext*, swift::SwiftError*) + 1
Thread 1:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x182e41c34 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x182e54574 mach_msg2_internal + 76
2 libsystem_kernel.dylib 0x182e4a9c0 mach_msg_overwrite + 480
3 libsystem_kernel.dylib 0x182e41fc0 mach_msg + 24
4 CoreFoundation 0x182f430d8 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x182f419c4 __CFRunLoopRun + 1188
6 CoreFoundation 0x1830141c4 _CFRunLoopRunSpecificWithOptions + 532
7 AppKit 0x187491c7c _NSEventThread + 184
8 libsystem_pthread.dylib 0x182e85c58 _pthread_start + 136
9 libsystem_pthread.dylib 0x182e80c1c thread_start + 8
Thread 2:
Thread 3:
Thread 4:
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000000 x1: 0x0000000000000000 x2: 0x0000000000000000 x3: 0x0000000000000000
x4: 0xfffffffce49ab0b0 x5: 0x0000000000000010 x6: 0xffffffffbfc007ff x7: 0xfffff0003ffff800
x8: 0xe179ad60e80217de x9: 0xe179ad610702495e x10: 0x0000000000000002 x11: 0x00000000fffffffd
x12: 0x0000000000000000 x13: 0x0000000000000000 x14: 0x0000000000000000 x15: 0x0000000000000000
x16: 0x0000000000000148 x17: 0x00000001f0643000 x18: 0x0000000000000000 x19: 0x0000000000000006
x20: 0x0000000000000103 x21: 0x00000001ef005f60 x22: 0x000000016d505388 x23: 0x000000016d505370
x24: 0x0000000000000004 x25: 0x00000009c9d9f210 x26: 0x0000000000000004 x27: 0x0000000196aaffd8
x28: 0x0000000196aaffd8 fp: 0x000000016d505280 lr: 0x0000000182e858d8
sp: 0x000000016d505260 pc: 0x0000000182e4a5e8 cpsr: 0x40000000
far: 0x0000000000000000 esr: 0x56000080 (Syscall)
Binary Images:
0x1028f8000 - 0x102ecffff com.jimsmithsoftware.rvcarelogbook (4.0.11) <0d9275e4-498f-37b7-8dab-366539863b80> /Applications/RVCare Logbook.app/Contents/MacOS/RVCare Logbook
0x103418000 - 0x103423fff libobjc-trampolines.dylib () /usr/lib/libobjc-trampolines.dylib
0x117968000 - 0x11831ffff com.apple.AGXMetalG17G (351.2) <441ba161-fbf2-3cde-8b43-73dc52ca1fb5> /System/Library/Extensions/AGXMetalG17G.bundle/Contents/MacOS/AGXMetalG17G
0x182e41000 - 0x182e7e2af libsystem_kernel.dylib (
) /usr/lib/system/libsystem_kernel.dylib
0x182e7f000 - 0x182e8bb3b libsystem_pthread.dylib () <4f33683c-18c8-39a1-800b-2e3bd43bcc13> /usr/lib/system/libsystem_pthread.dylib
0x182d14000 - 0x182d94d9f libsystem_c.dylib (
) <694b7881-1bf3-3d0f-8f19-b50ae4e8ef8a> /usr/lib/system/libsystem_c.dylib
0x196544000 - 0x196ae57bf libswiftCore.dylib () <7669d858-d332-36c7-9c6c-4564ffbea8d2> /usr/lib/swift/libswiftCore.dylib
0x22f912000 - 0x22fa7e4bf com.apple.SwiftData (1.0) <69089200-c33b-348e-8e66-8c5954bcf335> /System/Library/Frameworks/SwiftData.framework/Versions/A/SwiftData
0x287807000 - 0x287892095 libswift_Concurrency.dylib (
) /usr/lib/swift/libswift_Concurrency.dylib
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x182ec5000 - 0x18342331f com.apple.CoreFoundation (6.9) <04e3598b-f226-3250-b3b2-ce938dd4db7e> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x187337000 - 0x188a59f9f com.apple.AppKit (6.9) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Full Report
{“app_name”:“RVCare Logbook”,“timestamp”:“2026-07-09 14:03:18.00 -0400”,“app_version”:“4.0.11”,“slice_uuid”:“0d9275e4-498f-37b7-8dab-366539863b80”,“adam_id”:“894039710”,“build_version”:“2091”,“bundleID”:“com.jimsmithsoftware.rvcarelogbook”,“platform”:1,“share_with_app_devs”:0,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 26.5.1 (25F80)”,“roots_installed”:0,“incident_id”:“2EBA2139-1F62-4730-8DF1-B9092EC6953A”,“name”:“RVCare Logbook”}
“uptime” : 36000,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “Mac17,3”,
“coalitionID” : 679,
“osVersion” : {
“train” : “macOS 26.5.1”,
“build” : “25F80”,
“releaseType” : “User”
“captureTime” : “2026-07-09 14:03:00.9905 -0400”,
“codeSigningMonitor” : 2,
“incident” : “2EBA2139-1F62-4730-8DF1-B9092EC6953A”,
“pid” : 629,
“translated” : false,
“cpuType” : “ARM-64”,
“procLaunch” : “2026-07-08 17:56:06.4055 -0400”,
“procStartAbsTime” : 2557842372,
“procExitAbsTime” : 886416332459,
“procName” : “RVCare Logbook”,
“procPath” : “/Applications/RVCare Logbook.app/Contents/MacOS/RVCare Logbook”,
“bundleInfo” : {“CFBundleShortVersionString”:“4.0.11”,“CFBundleVersion”:“2091”,“CFBundleIdentifier”:“com.jimsmithsoftware.rvcarelogbook”},
“storeInfo” : {“storeCohortMetadata”:“10|date=1781658000000&sf=143441&app=com.apple.AppStore&pgtp=Software&pgid=894039710&prpg=Search_osx&ctxt=Search&issrch=1&lngid=1”,“itemID”:“894039710”,“deviceIdentifierForVendor”:“9EE0D891-9B7F-5594-A7C1-DC340ED9E484”,“thirdParty”:true,“softwareVersionExternalIdentifier”:“887913340”},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “com.jimsmithsoftware.rvcarelogbook”,
“crashReporterKey” : “807D8CDC-F379-CAAE-98B9-34C3A047F954”,
“appleIntelligenceStatus” : {“state”:“available”},
“developerMode” : 1,
“codeSigningID” : “com.jimsmithsoftware.rvcarelogbook”,
“codeSigningTeamID” : “337D5WLPMY”,
“codeSigningFlags” : 570520337,
“codeSigningValidationCategory” : 4,
“codeSigningTrustLevel” : 4294967295,
“codeSigningAuxiliaryInfo” : 0,
“instructionByteStream” : {“beforePC”:“fyMD1f17v6n9AwCRCuD/l78DAJH9e8Go/w9f1sADX9YQKYDSARAA1A==”,“atPC”:“AwEAVH8jA9X9e7+p/QMAkf/f/5e/AwCR/XvBqP8PX9bAA1/WcAqA0g==”},
“bootSessionUUID” : “8416DE7C-439D-466C-83C7-255381A3913B”,
“wakeTime” : 3354,
“sleepWakeUUID” : “2DC7FFE0-EC2E-411D-BE2E-CA850296B586”,
“sip” : “enabled”,
“exception” : {“codes”:“0x0000000000000000, 0x0000000000000000”,“rawCodes”:[0,0],“type”:“EXC_CRASH”,“signal”:“SIGABRT”},
“termination” : {“flags”:0,“code”:6,“namespace”:“SIGNAL”,“indicator”:“Abort trap: 6”,“byProc”:“RVCare Logbook”,“byPid”:629},
“asi” : {“libsystem_c.dylib”:[“abort() called”]},
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:6043,“threadState”:{“x”:[{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:18446744060365025456},{“value”:16},{“value”:18446744072631617535},{“value”:18446726482597246976},{“value”:16247207762436691934},{“value”:16247207762956798302},{“value”:2},{“value”:4294967293},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:328},{“value”:8328065024},{“value”:0},{“value”:6},{“value”:259},{“value”:8304746336,“symbolLocation”:224,“symbol”:“_main_thread”},{“value”:6128948104},{“value”:6128948080},{“value”:4},{“value”:42041209360},{“value”:4},{“value”:6822756312,“symbolLocation”:0,“symbol”:“class metadata base offset for KeyPath”},{“value”:6822756312,“symbolLocation”:0,“symbol”:“class metadata base offset for KeyPath”}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6491232472},“cpsr”:{“value”:1073741824},“fp”:{“value”:6128947840},“sp”:{“value”:6128947808},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6490990056,“matchesCrashFrame”:1},“far”:{“value”:0}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:38376,“symbol”:“__pthread_kill”,“symbolLocation”:8,“imageIndex”:3},{“imageOffset”:26840,“symbol”:“pthread_kill”,“symbolLocation”:296,“imageIndex”:4},{“imageOffset”:493124,“symbol”:“abort”,“symbolLocation”:148,“imageIndex”:5},{“imageOffset”:426220,“symbol”:“swift::fatalErrorv(unsigned int, char const*, char*)”,“symbolLocation”:144,“imageIndex”:6},{“imageOffset”:426252,“symbol”:“swift::fatalError(unsigned int, char const*, …)”,“symbolLocation”:32,“imageIndex”:6},{“imageOffset”:377420,“symbol”:“swift::swift_dynamicCastFailure(void const*, char const*, void const*, char const*, char const*)”,“symbolLocation”:80,“imageIndex”:6},{“imageOffset”:377844,“symbol”:“swift::swift_dynamicCastFailure(swift::TargetMetadataswift::InProcess const*, swift::TargetMetadataswift::InProcess const*, char const*)”,“symbolLocation”:164,“imageIndex”:6},{“imageOffset”:34700,“symbol”:“swift_dynamicCast”,“symbolLocation”:288,“imageIndex”:6},{“imageOffset”:1208628,“imageIndex”:7},{“imageOffset”:1197060,“imageIndex”:7},{“imageOffset”:747044,“imageIndex”:7},{“imageOffset”:3266668,“imageIndex”:0},{“imageOffset”:3074660,“imageIndex”:0},{“imageOffset”:3462956,“imageIndex”:0},{“imageOffset”:88324,“imageIndex”:0},{“imageOffset”:3767173,“imageIndex”:0},{“imageOffset”:38033,“imageIndex”:0},{“imageOffset”:131689,“imageIndex”:0},{“imageOffset”:131693,“imageIndex”:0},{“imageOffset”:52933,“symbol”:“completeTaskWithClosure(swift::AsyncContext*, swift::SwiftError*)”,“symbolLocation”:1,“imageIndex”:8}]},{“id”:6407,“name”:“com.apple.NSEventThread”,“threadState”:{“x”:[{“value”:268451845},{“value”:21592279046},{“value”:8589934592,“objc-selector”:“6EF65EE047C0558F6317C12EBB41MockGetContactQuickActionButtonsViewModel”},{“value”:128655745351680},{“value”:0},{“value”:128655745351680},{“value”:2},{“value”:4294967295},{“value”:0},{“value”:17179869184},{“value”:0},{“value”:2},{“value”:0},{“value”:0},{“value”:29955},{“value”:5497558140160},{“value”:18446744073709551569},{“value”:8328066832},{“value”:0},{“value”:4294967295},{“value”:2},{“value”:128655745351680},{“value”:0},{“value”:128655745351680},{“value”:21592279046},{“value”:6132375688},{“value”:8589934592,“objc-selector”:“6EF65EE047C0558F6317C12EBB41MockGetContactQuickActionButtonsViewModel”},{“value”:18446744073709550527},{“value”:4412409862}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:6491030900},“cpsr”:{“value”:0},“fp”:{“value”:6132375536},“sp”:{“value”:6132375456},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6490954804},“far”:{“value”:0}},“frames”:[{“imageOffset”:3124,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:3},{“imageOffset”:79220,“symbol”:“mach_msg2_internal”,“symbolLocation”:76,“imageIndex”:3},{“imageOffset”:39360,“symbol”:“mach_msg_overwrite”,“symbolLocation”:480,“imageIndex”:3},{“imageOffset”:4032,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:3},{“imageOffset”:516312,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:160,“imageIndex”:10},{“imageOffset”:510404,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1188,“imageIndex”:10},{“imageOffset”:1372612,“symbol”:“_CFRunLoopRunSpecificWithOptions”,“symbolLocation”:532,“imageIndex”:10},{“imageOffset”:1420412,“symbol”:“_NSEventThread”,“symbolLocation”:184,“imageIndex”:11},{“imageOffset”:27736,“symbol”:“_pthread_start”,“symbolLocation”:136,“imageIndex”:4},{“imageOffset”:7196,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:4}]},{“id”:502972,“frames”:,“threadState”:{“x”:[{“value”:6133526528},{“value”:130603},{“value”:6132989952},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:0},“fp”:{“value”:0},“sp”:{“value”:6133526528},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6491212808},“far”:{“value”:0}}},{“id”:502973,“frames”:,“threadState”:{“x”:[{“value”:6134099968},{“value”:101795},{“value”:6133563392},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:0},“fp”:{“value”:0},“sp”:{“value”:6134099968},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6491212808},“far”:{“value”:0}}},{“id”:502974,“frames”:,“threadState”:{“x”:[{“value”:6134673408},{“value”:121139},{“value”:6134136832},{“value”:0},{“value”:409604},{“value”:18446744073709551615},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0},{“value”:0}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:0},“cpsr”:{“value”:0},“fp”:{“value”:0},“sp”:{“value”:6134673408},“esr”:{“value”:1442840704,“description”:“(Syscall)”},“pc”:{“value”:6491212808},“far”:{“value”:0}}}],
“usedImages” : [
“source” : “P”,
“arch” : “arm64”,
“base” : 4337926144,
“CFBundleShortVersionString” : “4.0.11”,
“CFBundleIdentifier” : “com.jimsmithsoftware.rvcarelogbook”,
“size” : 6127616,
“uuid” : “0d9275e4-498f-37b7-8dab-366539863b80”,
“path” : “/Applications/RVCare Logbook.app/Contents/MacOS/RVCare Logbook”,
“name” : “RVCare Logbook”,
“CFBundleVersion” : “2091”
“source” : “P”,
“arch” : “arm64e”,
“base” : 4349591552,
“size” : 49152,
“uuid” : “ca58aa96-b997-3a6d-9132-19d49be4b3e9”,
“path” : “/usr/lib/libobjc-trampolines.dylib”,
“name” : “libobjc-trampolines.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 4690706432,
“CFBundleShortVersionString” : “351.2”,
“CFBundleIdentifier” : “com.apple.AGXMetalG17G”,
“size” : 10190848,
“uuid” : “441ba161-fbf2-3cde-8b43-73dc52ca1fb5”,
“path” : “/System/Library/Extensions/AGXMetalG17G.bundle/Contents/MacOS/AGXMetalG17G”,
“name” : “AGXMetalG17G”,
“CFBundleVersion” : “351.2”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6490951680,
“size” : 250544,
“uuid” : “cc1cf985-bc65-3725-809f-4c1e36b8f4ba”,
“path” : “/usr/lib/system/libsystem_kernel.dylib”,
“name” : “libsystem_kernel.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6491205632,
“size” : 52028,
“uuid” : “4f33683c-18c8-39a1-800b-2e3bd43bcc13”,
“path” : “/usr/lib/system/libsystem_pthread.dylib”,
“name” : “libsystem_pthread.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6489718784,
“size” : 527776,
“uuid” : “694b7881-1bf3-3d0f-8f19-b50ae4e8ef8a”,
“path” : “/usr/lib/system/libsystem_c.dylib”,
“name” : “libsystem_c.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6817071104,
“size” : 5904320,
“uuid” : “7669d858-d332-36c7-9c6c-4564ffbea8d2”,
“path” : “/usr/lib/swift/libswiftCore.dylib”,
“name” : “libswiftCore.dylib”
“source” : “P”,
“arch” : “arm64e”,
“base” : 9387974656,
“CFBundleShortVersionString” : “1.0”,
“CFBundleIdentifier” : “com.apple.SwiftData”,
“size” : 1492160,
“uuid” : “69089200-c33b-348e-8e66-8c5954bcf335”,
“path” : “/System/Library/Frameworks/SwiftData.framework/Versions/A/SwiftData”,
“name” : “SwiftData”,
“CFBundleVersion” : “135”
“source” : “P”,
“arch” : “arm64e”,
“base” : 10863276032,
“size” : 569494,
“uuid” : “e3545aa1-ff13-3698-8657-91bb23002df9”,
“path” : “/usr/lib/swift/libswift_Concurrency.dylib”,
“name” : “libswift_Concurrency.dylib”
“size” : 0,
“source” : “A”,
“base” : 0,
“uuid” : “00000000-0000-0000-0000-000000000000”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6491492352,
“CFBundleShortVersionString” : “6.9”,
“CFBundleIdentifier” : “com.apple.CoreFoundation”,
“size” : 5628704,
“uuid” : “04e3598b-f226-3250-b3b2-ce938dd4db7e”,
“path” : “/System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation”,
“name” : “CoreFoundation”,
“CFBundleVersion” : “5026.5.4”
“source” : “P”,
“arch” : “arm64e”,
“base” : 6563262464,
“CFBundleIdentifier” : “com.apple.AppKit”,
“size” : 24260512,
“uuid” : “cf57a4fc-4be3-3d95-b543-d744e8718b26”,
“path” : “/System/Library/Frameworks/AppKit.framework/Versions/C/AppKit”,
“name” : “AppKit”,
“CFBundleVersion” : “2685.60.104”
“sharedCache” : {
“base” : 6486048768,
“size” : 5990596608,
“uuid” : “ff7119a7-f64d-305d-8135-7e6eb1c207d1”
“legacyInfo” : {
“threadTriggered” : {
“queue” : “com.apple.main-thread”
“logWritingSignature” : “56cb5d5ee54379c10b7b7491f1b81a9e7252c87d”,
“bug_type” : “309”,
“roots_installed” : 0,
“trmStatus” : 1,
“trialInfo” : {
“rollouts” : [
“rolloutId” : “60da5e84ab0ca017dace9abf”,
“factorPackIds” : [
  "deploymentId" : 240000008
  "rolloutId" : "695fd05d8ca5554688521e5e",
  "factorPackIds" : [
    "695fd08781fcd20ded79c1d3",
    "695fd0d28ca5554688521e5f",
    "695fd09c8774dc09015a80e9",
    "695fd0b18774dc09015a80ea"
  "deploymentId" : 3
“experiments” : [
Model: Mac17,3, BootROM 18000.120.36, proc 10:4:6:0 processors, 16 GB, SMC
Graphics: Apple M5, Apple M5, Built-In
Display: Color LCD, 2560 x 1664 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Micron
AirPort: chip id: 0x11 api 1.2 firmware [Rev 72.129.725 N1B1 devFused=0] phy [20.1.62.0], core80211 [324.129.732 N1_silicon_b ], Apr 18 2026 18:00:58 version XBS_BUILD_TAG GIT_DESCRIBE FWID chip id: 0x11 api 1.2 firmware [Rev 72.129.725 N1B1 devFused=0] phy [20.1.62.0], core80211 [324.129.732 N1_silicon_b ]
IO80211_driverkit-1561.3 “IO80211_driverkit-1561.3” Apr 18 2026 17:42:26
AirPort:
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Thunderbolt Bus: MacBook Air, Apple Inc.
Now I cant even reload backup or the last file I had, it just crashes completely out. All the backups it makes are only 47kb the last big backup was 969kb but it crashes also
