now they sync, its to strange, some times it syncs immediately yet today i entered service and notes and 4 hours later nothing. now it syncs again
BUT Vehicles still has no syncing between phone and laptop
Is there anything in the Sync Diagnostics on either phone or laptop? Please check under Settings > Data > Show Sync Diagnostics. If there are any errors in either, can you please paste them here if possible? (There is a ācopyā button which will put the diagnostics onto the clipboard.) Thanks.
Version 4.0.7 (2075) | macOS 26.5.1
Generated: Jun 19, 2026 at 9:19 AM
Last successful sync: 9:19 AM (143 successes this session)
⢠[8:24 PM] Export ā Partial failure [CK2] Ā· domain=CKErrorDomain | code=2
Sync detail (last 10 min):
8:24:15 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _exportFinishedWithResult:exporter:: : Export failed with error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0xabd308d20 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
8:24:15 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate recoverFromError:: - Attempting recovery from error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0xabd308d20 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
8:24:15 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _recoverFromPartialError:forStore:inMonitor:: : Error recovery failed because the following fatal errors were found:
8:24:15 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:: - resetting internal state after error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0xabd308d20 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
8:24:15 PM CoreData+CloudKit: -NSCloudKitMirroringDelegate _requestAbortedNotInitialized:: - Never successfully initialized and cannot execute request āā due to error: Error Domain=CKErrorDomain Code=2 UserInfo={ContainerID=, NSDebugDescription=, CKPartialErrors=, RequestUUID=, NSLocalizedDescription=, CKErrorDescription=, NSUnderlyingError=0xabd308d20 {Error Domain=CKInternalErrorDomain Code=1011 UserInfo={CKErrorDescription=, NSLocalizedDescription=, CKPartialErrors=}}}
8:24:20 PM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason:
8:40:25 PM CoreData+CloudKit: -[NSCloudKitMirroringDelegate _respondToPushNotification:forSubscription:]_block_invoke(915): - Not reviving the mirroring delegate (CKErrorDomain:2) after notification for subscription: com.apple.coredata.cloudkit.private.subscription
Version 4.0.7 (2075) | iOS 26.5.1 Ā· iPhone
Generated: Jun 19, 2026 at 9:20 AM
Last successful sync: 9:20 AM (113 successes this session)
⢠[9:20 AM] Export ā The operation couldnāt be completed. (Cocoa error 134419.) Ā· domain=NSCocoaErrorDomain | code=134419
9:20:05 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate _exportFinishedWithResult:exporter:](1486): : Export failed with error: Error Domain=NSCocoaErrorDomain Code=134419 āThe request was aborted because it was deferred by the system.ā UserInfo={NSLocalizedFailureReason=The request was aborted because it was deferred by the system.}
9:20:10 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate resetAfterError:andKeepContainer:](589): - resetting internal state after error: Error Domain=NSCocoaErrorDomain Code=134422 āCloudKit setup failed because it couldnāt register a handler for the export activity. There is another instance of this persistent store actively syncing with CloudKit in this process.ā UserInfo={NSUnderlyingException=Illegal attempt to register a second handler for activity identifier com.apple.coredata.cloudkit.activity.export.E3158173-A36C-4EC4-B4BE-0DFD2B73A5CE, NSURL=, activityIdentifier=, NSLocalizedFailureReason=CloudKit setup failed because it couldnāt register a handler for the export activity. There is another instance of this persistent store actively syncing with CloudKit in this process.}
9:20:10 AM CoreData+CloudKit: -[NSCloudKitMirroringDelegate tearDown:]_block_invoke(797): : Told to tear down with reason:
Just so Iām clear, most other items are syncing properly? If you make a change to a campground, that syncs?
I added a reservation to the phone and it showed up on the laptop and ALSO the vehicles has started syncing? I have no excuse lol
The diagnostics that you posted show that something was wrong. That isnāt uncommon with cloud syncing - momentary network drops, sync clashes and more would cause a quick error - but itās supposed to recover automatically and silently. Iāll look into tightening this up, glad itās working (for now!)
