Campground Reservation issues
So now that you taught me to look elsewhere for ‘+’ marks , I’ve started to use visit history. I do not see any visit history on the iPhone or iPad but all my previous visit history is showing on the laptop. Again, I don’t know if it has made its way to the iCloud but I did use the same 3.0 database when originally building the iPad and iPhone data. That includes the four ‘new’ campgrounds I have entered and also entered visit history. They see the Campground general record but no visit history record shows.
In addition, the entry screen lets me enter arrival and departure dates as long as they are 1 day apart which my first four were but in trying to enter one that is eight days later departure, the screen goes blank and I lose this record. I have tried multiple ways to enter the departure date (to try to avoid the popup calendar) but nothing appears to work. I select June 13th as arrival date, adjust the time, go to put in the departure date of June 21st and the record disappears - back to entry screen that says 'tap '+" to record visit. Fortunately, it doesn’t seem to affect any other record (we have stayed here before). When I start to enter, it say 2 of 2 records with the arrows but as soon as it disappears, it doesn’t show anything but if I go away from that Campground and come back, the visit history 1 of 1 is there. I even put all the info in the 2nd visit history record by leaving the departure date as June 14th (1 day) which worked - I could look at both visit records but when I went back and changed the departure date to June 21, the record disappeared and we were back to 1 of 1.
v 4.0.6 on Mac Air with Tahoe 26.5.1
@SteveJ - I’m pretty sure it wasn’t deleting the record, but filtering incorrectly. Not good either way. I’ve made some changes in the next version and the user experience should be much nicer now. When clicking Campgrounds, you’ll now see two tabs: Campgrounds (lists all the campgrounds), and Reservations (which shows all of your upcoming reservations, regardless of which campground they are in).
Next, if you tap the Reservations tab (see screenshot), you’ll notice two tabs: Upcoming and Past Visits, which should be self-explanatory. I’ve removed the delete button (as it was too close to the little Add button), and it’s now at the bottom of the reservation.
To further clean up the interface, if there are multiple reservations (or past visits), you’ll now see a popup menu (see second screenshot). The popup menu allows you to select different reservations by date, and should be a lot clearer.
I think this works much better now, but I’m definitely open to suggestions to tweak this further.
