Campground reservation add to calendar
Wonder if it is possible to ‘permanently’ change the answer to ‘add to calendar’ to ‘check, added to calendar’. I know it makes that statement when you add to calendar (I caught it flash by while adding a reservation) but it changed back almost immediately to ‘add to calendar’ which may lead a person (ME) to add it multiple times.
thanks, steve
Great point, I’ll come up with something for that.
Next build should be with you in the next 24 hours.
Well, that was a nice easy one.
After tapping Add to Calendar, the button now says Added to Calendar with a checkmark, so it’s quite clear. This will be synced across all devices. The button still works, so tapping it again will add it to the calendar again, which could be useful.
