Sync Issues between platforms
File sent.
That’s what I did before I sent the last sync diagnostics, but I have done it again.
Sync log from iPhone. Different this time!!!
Version 4.0 (2055) | iOS 26.4.1 · iPhone
Generated: 21 Apr 2026 at 18:36
Last successful sync: 18:36 (5 successes this session)
No errors in the last 24 hours.
Raw sync log (last 10 min):
18:36:08 [com.apple.coredata/error] CoreData: error: Failed to stat path ‘/private/var/mobile/Containers/Shared/AppGroup/63894BEE-3AB4-40C7-A76C-E828AC6ACDF4/Library/Application Support/default.store’, errno 2 / No such file or directory.
18:36:08 [com.apple.coredata/error] CoreData: error: Executing as effective user 501
18:36:08 [com.apple.coredata/error] CoreData: error: Sandbox access to file-write-create denied
18:36:08 [com.apple.coredata/error] CoreData: error: Failed to statfs file; errno 2 / No such file or directory.
18:36:08 [com.apple.coredata/error] CoreData: error: Information for file system
18:36:08 [com.apple.coredata/error] CoreData: error: ---------------------------
18:36:08 [com.apple.coredata/error] CoreData: error: File system type: 0
18:36:08 [com.apple.coredata/error] CoreData: error: File system flags: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Total data blocks: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Free data blocks: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Free blocks for nonsuperuser: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Total i-nodes: 0
18:36:08 [com.apple.coredata/error] CoreData: error: File system ID: 0, 0
18:36:08 [com.apple.coredata/error] CoreData: error: Free i-nodes: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Owner UID: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Filesystem type name:
18:36:08 [com.apple.coredata/error] CoreData: error: Mount on name:
18:36:08 [com.apple.coredata/error] CoreData: error: Mount from name:
18:36:08 [com.apple.coredata/error] CoreData: error: Failed to stat path ‘/private/var/mobile/Containers/Shared/AppGroup/63894BEE-3AB4-40C7-A76C-E828AC6ACDF4/Library/Application Support’, errno 2 / No such file or directory.
18:36:08 [com.apple.coredata/error] CoreData: error: Information for /private/var/mobile/Containers/Shared/AppGroup/63894BEE-3AB4-40C7-A76C-E828AC6ACDF4/Library
18:36:08 [com.apple.coredata/error] CoreData: error: File Device ID: 0
18:36:08 [com.apple.coredata/error] CoreData: error: Device ID: 16777225
18:36:08 [com.apple.coredata/error] CoreData: error: File Size: 128 bytes
18:36:08 [com.apple.coredata/error] CoreData: error: File inode: 7830994
18:36:08 [com.apple.coredata/error] CoreData: error: File user ID: 501
18:36:08 [com.apple.coredata/error] CoreData: error: File group ID: 501
18:36:08 [com.apple.coredata/error] CoreData: error: File Permissions:
18:36:08 [com.apple.coredata/error] CoreData: error: d
18:36:08 [com.apple.coredata/error] CoreData: error: 755
18:36:08 [com.apple.coredata/error] CoreData: error: file is not a symbolic link
18:36:08 [com.apple.coredata/error] CoreData: error: Sandbox access to file-write-create allowed
18:36:08 [com.apple.coredata/error] CoreData: error: File system type: 0x1a
18:36:08 [com.apple.coredata/error] CoreData: error: File system flags: 0x14809098
18:36:08 [com.apple.coredata/error] CoreData: error: MNT_JOURNALED
18:36:08 [com.apple.coredata/error] CoreData: error: Total data blocks: 62350741
18:36:08 [com.apple.coredata/error] CoreData: error: Free data blocks: 4614229
18:36:08 [com.apple.coredata/error] CoreData: error: Free blocks for nonsuperuser: 4614229
18:36:08 [com.apple.coredata/error] CoreData: error: Total i-nodes: 185171586
18:36:08 [com.apple.coredata/error] CoreData: error: File system ID: 0x1000009, 0x1a
Just to let you know that build 2061 is still having problems adding photos to campgrounds. It is causing a sync failure as before. The only photos I have been able to add without this problem was for the vehicle section where it seems to work fine.
