Problem with reservation add on iPad
In trying to rebuilt all the lost data, I decided to use my iPad since I can’t trust the laptop. In entering a reservation it is FAR too easy to hit the ‘delete’ band at the bottom while trying to scroll up to see more data. Lost two entries while entering because it is so easy to do. Needs to either ‘ask’ if you really want to delete or be moved to somewhere safer . . .
another issue: you cannot enter an ‘upcoming’ registration if the start date is past so you have to enter it as a past reservation. ok, that makes sense BUT if you enter an end date that is in the future (even tomorrow’s date), the entry screen disappears and you are left with any past reservations you have previously entered. Opps . . now you are in edit mode of a previous reservation and if you don’t catch on, you are changing data. The actual reservation you were entering is now under the upcoming reservation tab, without any warning. I would think it at least needs a warning that it is now under the upcoming tab or just automatically open the upcoming tab with the entry screen ready to continue . . .
